Hi @Pete_c,
I am seeing changes in the console of the switch when physically touching or moving the virtual slider only once . If I switch off the dimmer from physically and again switch it back then I dont see changes in console, I must do dimming and switch on/off from console once to use physical dimmer.
I was able to successfully flash 2 dimmers earlier this month using OTA with opening and soldering. Model are DS1 , so I ordered same models but these are not working correctly.
I also noticed one difference in working dimmer and this dimmer is Flash size , all working dimmer have 1024kB size and this dimmer has 2048kB size, not sure if this is problem or not. But issue I am facing is physical function and console function are not in sync.
Would appreciate your help.
