PaulD
I have 2 metal gates with a deadbolt to secure them. Looking for a way to monitor the deadbolt position so I can verify the gate is actually locked. No viable way to run wire to them so I need a wireless solution. I currently have a Omni Pro II with a GE wireless receiver as well as an X-10 receiver so that gives me 2 options for a wireless connection.
The dead bolt is completely enclosed in the gate and frame much like a normal door so there is no easy access. I think the most viable solution involves drilling a hole in the side of the frame (1" square tube) that the dead bolt engages in such that the side of the dead bolt can be seen if the gate is locked. That should allow me to install some type of widget in that hole that would create an open or closed circuit when the gate is locked. My current thinking is that some type of simple spring loaded switch mounted in that hole which is then wired via short run of wire to a wireless transmitter woud do the trick. My problem is that I have not been able to determine what combination of pieces would fit the bill and be suitable for outdoor use.
Anyone have any bright ideas?
