Wireless sensor for ELK
pinkfish
Morning,
I have a wireless 6020 sensor for my ELK security system, but I cannot get the elk to notice events from it.  It never seems to move to the violated status.  I can see the led flash green, rather than red, so it seems to be correctly connected to the wireless transmitter.  Are there are settings or something I might be missing?
I followed the directions on the instructions that come with the wireless sensor in terms of registering it.
David.
Check to make sure the M1XRFTW is set to Address 2, the M1XRFTW is enrolled, the M1 is running Firmware 5.2.10 and the Loop for the 6020 is set to 2
I checked those things and it seems to be right, I can see the transmit lights flashing on the m1xftw when the sensor is tripped.  What type of contact do I set it up as?  I have it as a EOL Hardwire/wireless, I also tried normally closed and they both don't seem to trip anything when the sensor changes, although I can see it flashing.  Nothing shows up as an error or anything in the logs either.
Ok, figured out that the wireless module itself was not enrolled on the data bus.  Now it is and it works.  Thanks!
