Wireless sensors...
noshali
What ALL do I need to connect the wireless motion sensors to my elk m1gold? I have a couple Caddx ones that came with my ge security system.
I believe it is the NX-448E and W035A. Is there anything else I need??
Regards,
I think that should be all you need, unless you want the enclosure? But actually I have a question for Spanky - can you extend the W035 cable so you can put the receiver and enclosure in the attic?
I extended mine about 40 or 50 feet since my panel is in the basement. No problems. I think the installation instructions say you can go to 200 feet but I cant be sure.
Dont leave it in the cabinet. I remember reading somewhere that the range is slightly limited. They sell a plastic enclosure for the Caddix recevier for about $10 for mounting it remotely.
Great. Spent all weekend puttting up the panel wall in the basement. I was thinking about putting it in the basement. So what is the range on this baby???
Any suggestions. The distance of the furthest sensor will be on the top floor. About 70 feet away.
Regards,
noshali,
You should be fine. Like everything else wireless, the distance is effected by building materials (wood = good, stone/concrete = not so good, metal = bad), mounting location (higher = better), and ambient electrical noise (downtown NYC = bad, South Podunk Utah = good).
Also, remember that the stuff you are installing is commercial quality equipment (unlike the cr*p that X10 sells). If the equipment didn't work in 99% of the installations, Caddx would start to lose sales in a hurry.
When mounting the Caddx RF receiver, get the optional mounting box and move it away from the M1. This may increase the receive range.
Not to dispute David, but for a regular residential install, you might want to first try mounting the receiver with the M1.
I have the Receiver mounted in the same box as the M1, in a wiring closet with a 200 amp panel, 1 subpanel, two video amplifiers, my Homeseer PC, an Ocelot, what looks to be about a mile of wiring, AND the incoming water line for the house. Oh, yeah - and it's in the far corner of the basement!
Works fine all the way to the other far corner of the second story of the house, through a layer of Mexican tile and a bunch of granite.
This Caddx stuff is incredible...
I installed in the basement and it works fine. It is next to the furnace...and has the water heater etc there as well. A lot of metal....I will do some more tests with my keyfob from the driveway so that I can see the range.
regards,
Let me restate that: If you are on the fringe of the range of the Caddx receiver, moving the receiver outside the metal can, say 10 feet or more away from the control, may increase the operational range.
At my house the Caddx receiver is in the metal can and the whole house is covered. The control is located in the basement.
GE Caddx wireless is what type of wireless. Is it secure? Does it use encryption? What frequencies does it operate on? How does it match sensors to receivers (create a link)? Can two systems interfere with each other? Are devices polled or do they periodically transmit their state?
Tom
