I'm running into a roadblock trying to use the trigger from my Yamaha RX-A3000. I have it set to trigger high when the receiver goes on, so it throws a constant 12v across the line when the yamaha is on and nothing when it is off (I have tested it and it throws 12v). I purchased an ELK-924 sensitive relay to facilitate my external relay. The 924 requires a secondary power supply so I put 12v on the power side and hooked up the yamaha via a standard 1/8 mono plug to bare wire and hooked the + trigger on the board to the +12v trigger output and it turns the LED on the relay on faintly (at all times) but doesn't trigger when I turn the yamaha on. The instructions say I can use EITHER a + or - trigger (but doesn't show both) If I add the - from the trigger it triggers the relay, even when the yamaha is off (which says I have a ground). When I measure voltage from the yamaha it's ZERO (+/- .001v) when the yamaha is off, but if I hook the positive to the - trigger on the relay it does nothing when the yamaha is off or on.
The Yamaha trigger is supposed to throw 12v 15mA when on, so that is more than enough to trigger the sensitive relay requirement of 1.2mA
Stumped in MA
Mike
Stumped in MA
Mike
