Zooz recently announced via twitter customers can now download firmware updates for the Zooz Z-Wave hardware. While this isn't a friction-less process (I'd love to see the registration requirement go away), it's a major step in the right direction.
As of right now, the following devices can be registered:
Jasco recently announced a similar decision, after Linus Tech Tips unveiled their struggles with Jasco hardware, which highlighted the issue of not being able to download firmware. This created enough pressure for Jasco to post the firmware on GitHub.
Get direct access to firmware files, extended warranty & expedited support when you join our Product Registration Portal - no need to reach out to support!
- ZAC36 Titan Water Valve
- ZEN04 Smart Plug
- ZEN05 Outdoor Plug
- ZEN06 Smart Plug
- ZEN14 Double Outdoor Plug
- ZEN15 Power Switch
- ZEN16 MultiRelay
- ZEN17 Universal Relay
- ZEN20 Power Strip
- ZEN21 On/Off Switch (500 series)
- ZEN22 Dimmer (500 series)
- ZEN23 Toggle Switch (500 series)
- ZEN24 Toggle Dimmer (500 series)
- ZEN25 Double Plug
- ZEN26 S2 On/Off Switch (500 series)
- ZEN27 S2 Dimmer (500 series)
- ZEN30 Double Switch
- ZEN31 RGBW Dimmer
- ZEN32 Scene Controller
- ZEN34 Remote Switch
- ZEN51 Dry Contact Relay
- ZEN52 Double Relay
- ZEN71 On/Off Switch (700 series)
- ZEN72 Dimmer (700 series)
- ZEN73 Toggle Switch (700 series)
- ZEN74 Toggle Dimmer (700 series)
- ZEN76 S2 On/Off Switch (700 series)
- ZEN77 S2 Dimmer (700 series)
- ZSE11 Q Sensor
- ZSE18 S2 Motion Sensor
- ZSE19 MultiSiren
- ZSE29 Outdoor Motion Sensor
- ZSE40 4-in-1 Sensor (500 series)
- ZSE40 700 4-in-1 Sensor (700 series)
- ZSE41 Open Close XS Sensor
- ZSE42 Water Leak XS Sensor
- ZSE43 Tilt Shock XS Sensor
- ZSE44 Temperature Humidity XS Sensor
- ZST10 Z-Wave Stick (500 series)
- ZST10 700 Z-Wave Stick (700 series)
