Zwave module for engine shutters without limit ?
doryphore
Hello,
Are there any Zwave module for controlling motors of roller shutters on which there is no limit ?
I tried with modules for duwi shutters (5436) but they only store the operating time, without storing high level not to exceed
thank you in advance for this information
Michel Courbet
You could use a low voltage control circuit with a zwave module. This would interface with a relay or motor contactor to inturn power the motor(s). The zwave part would just need to act as a switch in a circuit with a DC source that can provide enough power to the contactor's coil to pull the contactor closed. The contactor would then have a high current voltage source to power the motors.
Thank you for your answer, etc6849
But I am very badly expressed, I would order an electric shutter in which there is no mechanical stop, with a module Zwave could replace mechanical limit for storing a high point and low point not to exceed
