FlyingDiver
I'm currently in the research phase for systems to be installed in a new home build this fall. I need to decide on a security system that's Home Automation friendly.
I was leaning towards an Elk M1G based system, as it seems to be popular with the DIY crowd. When I was discussing the home build with a custom integrator I'm considering using for some of the AV systems, he said to stay away from Elk and use DSC, as it has better third party integration. If I was going with the Elk, I'd be using an M1XEP and connecting to it via ethernet. If I go with the DSC, it would be an Envisalink 3 for ethernet connectivity.
Pros and cons of the two systems from a home automation integration viewpoint?
