Part of why I'm not touching it or doing it for a bunch of my accounts. Kinda sucks, especially if anyone's been putting in M1's for any length of time. First the Caddx 548E (which I could understand once Elk came out with their own receiver). Now it's their own GE receiver and dropping support for it in favor of their unit that supports SAW and Crystal, so in theory, the receiver should be almost very similar in nature. Makes me wonder what is next for the GE receiver, which hopefully they don't drop (Elk's 2 way isn't what I'd choose if I was doing a 100% RF install) or what they'd do to the Honeywell unit.d.dennerline said:I wish Elk had not changed the 5.3.8 firmware and M1XRF2G requirements. I have migrated to Elk Two-way Wireless for everything except my Resolution Products driveway sensor (one of the most useful HA products I have installed). This means I have to buy the new GE replacement receiver for only one device.
elvisimprsntr said:You can eliminate the unassigned areas by adding, send to elk, delete, send all areas to elk. This will delete the unassigned areas which are restored during a factory reset. I was able to eliminate unassigned areas from all ISY and mobile app interfaces.
mikefamig said:Thanks for the word, I reverted back to 5.2 months ago due to reboots and I'm going to leave it at 5.2 until I have reason to believe that they fixed the problem.
Mike..
foxtail22 said:I just recently upgraded to 5.3.8 hoping it would eliminate the 1-2 time a month when I get random zone anouncements and emails but the zones are not tripping. The system worked well for 2 days and then the XEP stopped talking to my ISY and to ELKRP. A reset of the IP back to DHCP got ELKRP back in contact witht he XEP but not the ISY. After trying just about anything I could think of, I decided to check the DNS addresses and found that the router had a different DNS than the XEP and the ISY. I decided to try setting the XEP and the ISY DNS to that shown in the router. That seemed to cure the issue and the ISY and XEP began working properly.
I have found the XEP to have issues crawling out of network holes it finds itself in. I have had a couple of occasions where other devices on the LAN failed or a port on a switch failed and everything else kept working except the XEP and it some cases, it took a reset of the XEP to get it back on line. It also seems to try to hang onto prior configurations long after it should have given up and been more open to queries from new ports.
