ICS-DockStar etc # emerge --sync
>>> Starting rsync with rsync://67.212.64.3/gentoo-portage...
rsync: failed to connect to 67.212.64.3: Connection refused (111)
rsync error: error in socket IO (code 10) at clientserver.c(122) [Receiver=3.0.7]
>>> Retrying...
>>> Starting retry 1 of 3 with rsync://216.194.64.133/gentoo-portage
rsync: failed to connect to 216.194.64.133: Connection refused (111)
>>> Retrying...
>>> Starting retry 2 of 3 with rsync://129.97.134.71/gentoo-portage
rsync: failed to connect to 129.97.134.71: Connection refused (111)
>>> Retrying...
>>> Starting retry 3 of 3 with rsync://208.70.246.16/gentoo-portage
rsync: failed to connect to 208.70.246.16: Connection refused (111)
>>> Exceeded PORTAGE_RSYNC_RETRIES: 3
ICS-DockStar etc #
About a month ago bought a "bunch" of those little microSD "size" of the USB port dongles and was going to switch over to using that for the OS. Its so small you can't even tell its plugged. (using it now for my PBO stuff).
As for the calling home, I'm not totally convinced that there is a problem. My 1 hacked unit has called home, and I was able to get the Debian Script to install. My only hickup with the install was that I had to run the script, reboot, run a second time.
did you try to boot it without the drive attached?BTW just trashed my Seagate.....I was paying more attention last night than this morning to what I was doing. JTAG time. I was using a 20Gb drive. Went to partition it some more (I was using SDA 5,6,7) and wanted to configure it for SDA1, 2,3. Well started the process and it looks like I wrote over the boot init files as now it just keeps hopping on and off from the network and I cannot SSH or ping anymore. How easy and fast it is to turn into a brick.
I see "Hardware Error" when I ping it. Trying a reset using the little button on the side first. Didn't work.
Scanning JFFS2 FS: ....... done.
find_inode failed for name=uboot-original-mtd0.kwb
load: Failed to find inode
### JFFS2 LOAD ERROR<0> for uboot-original-mtd0.kwb!
### JFFS2 loading 'uboot-original-mtd0.kwb' to 0x800000
resetting ...
U-Boot 2010.09 (Oct 23 2010 - 11:49:22)
Marvell-Dockstar/Pogoplug by Jeff Doozan
SoC: Kirkwood 88F6281_A0
DRAM: 128 MiB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Net: egiga0
88E1116 Initialized on egiga0
Hit any key to stop autoboot: 0
Marvell>>
Marvell>> printenv
ethact=egiga0
bootdelay=3
baudrate=115200
mainlineLinux=yes
console=ttyS0,115200
led_init=green blinking
led_exit=green off
led_error=orange blinking
mtdparts=mtdparts=orion_nand:1M(u-boot),4M(uImage),32M(rootfs),-(data)
mtdids=nand0=orion_nand
partition=nand0,2
rescue_installed=0
rescue_set_bootargs=setenv bootargs console=$console ubi.mtd=2 root=ubi0:rootfs
ro rootfstype=ubifs $mtdparts $rescue_custom_params
rescue_bootcmd=if test $rescue_installed -eq 1; then run rescue_set_bootargs; na
nd read.e 0x800000 0x100000 0x400000; bootm 0x800000; else run pogo_bootcmd; fi
pogo_bootcmd=if fsload uboot-original-mtd0.kwb; then go 0x800200; fi
force_rescue=0
force_rescue_bootcmd=if test $force_rescue -eq 1 || ext2load usb 0:1 0x1700000 /
rescueme 1 || fatload usb 0:1 0x1700000 /rescueme.txt 1; then run rescue_bootcmd
; fi
ubifs_mtd=3
ubifs_set_bootargs=setenv bootargs console=$console ubi.mtd=$ubifs_mtd root=ubi0
:rootfs rootfstype=ubifs $mtdparts $ubifs_custom_params
ubifs_bootcmd=run ubifs_set_bootargs; if ubi part data && ubifsmount rootfs && u
bifsload 0x800000 /boot/uImage && ubifsload 0x1100000 /boot/uInitrd; then bootm
0x800000 0x1100000; fi
usb_scan=usb_scan_done=0;for scan in $usb_scan_list; do run usb_scan_$scan; if t
est $usb_scan_done -eq 0 && ext2load usb $usb 0x800000 /boot/uImage 1; then usb_
scan_done=1; echo "Found bootable drive on usb $usb"; setenv usb_device $usb; se
tenv usb_root /dev/$dev; fi; done
usb_scan_list=1 2 3 4
usb_scan_1=usb=0:1 dev=sda1
usb_scan_2=usb=1:1 dev=sdb1
usb_scan_3=usb=2:1 dev=sdc1
usb_scan_4=usb=3:1 dev=sdd1
usb_init=run usb_scan
usb_device=0:1
usb_root=/dev/sda1
usb_rootfstype=ext2
usb_rootdelay=10
usb_set_bootargs=setenv bootargs console=$console root=$usb_root rootdelay=$usb_
rootdelay rootfstype=$usb_rootfstype $mtdparts $usb_custom_params
usb_bootcmd=run usb_init; run usb_set_bootargs; run usb_boot
usb_boot=mw 0x800000 0 1; ext2load usb $usb_device 0x800000 /boot/uImage; if ext
2load usb $usb_device 0x1100000 /boot/uInitrd; then bootm 0x800000 0x1100000; el
se bootm 0x800000; fi
bootcmd=usb start; run force_rescue_bootcmd; run ubifs_bootcmd; run usb_bootcmd;
usb stop; run rescue_bootcmd; run pogo_bootcmd; reset
arcNumber=2097
stdin=serial
stdout=serial
stderr=serial
ethaddr=02:50:43:e8:52:f1
Environment size: 2261/131068 bytes
Marvell>>
