"two 30 AMP square D single throw tandem circuit breaker." (30 amps)
No, it's just a double pole breaker. See my link in post 39.
One can avoid all the complications discussed in this thread around how to install a Surge Suppressor Device (SPD; aka TVSS) adjacent the entrance box by installing one inside the box in a breaker position.
Just pop 'em in the position of duplex (2-pole) circuit breaker in the panel and connect the pigtail to neutral -- which in the entrance panel ONLY is the same as earth ground.
Manufacturer of panel and model number of appropriate inside-the-panel SPD :
GE ........................THQLSURGE
Westinghouse ..........BRSURGE
Cutler Hammer .........CHSA
Square D ................QO2175SB
Square D Homeline ...HOM2175SB
Siemens .................QSA1515, QSA2020 (superceded)
.............................QSA1515SPD, QSA2020SPD
The Siemens models have built in breakers (15 amp or 20 amp) that open if the SPD/TVSS is no longer effective which can both provide the signal output to inform an HA system of the failure and protect downstream equipment from damage.
HTH ... Marc
Marc,
You seem familiar with the Siemens TVSS device. I'm considering them (since I have Siemens panels), but I'm not sure if they will work for me. Maybe you know the answer.
Here's how my power goes...
POCO transformer on pole -> underground 30' -> meter box on outside of my shop/storage building -> ATS inside shop mounted directly behind meter box (also serves as service disconnect) -> 2' to shop's load center -> undergound 200' to my home -> home's load center.
I was thinking about adding the "breaker-style" TVSS's to both my home's panel and my shop's panel to protect circuits in both locations. However, in both of those panels, the neutrals float. The neutral and earth ground are only bonded/connected in the ATS, which is also the only box with a wire going to a ground rod. I've been told that I should have my home's panel directly connected to another ground rod (near my home), too, but even then, the neutral will still float. The TVSS breakers don't have a pigtail that connects directly to ground, so I'm wondering if they will work correctly in my home and shop subpanels. Any ideas?
Ira
Ira,
In-panel SPD/TVSS's are sold as providing protection from disturbances generated from within the local distribution system. And connecting the pigtail to neutral will do that.
When I first glanced at your post the words "shop" and " 200' " jumped out and I incorrectly mentally pictured sub-panel ( load center) in a shed 200 ft from the main entrance panel. In that case I would use a isolation transformer such as the 3KW one I bought last week new on eBay for $120.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...e=STRK:MEWNX:IT
which would allow one to have a proper local ground at the shed.
But that's not your circumstance.
Yes, as I understand it, you are supposed to -- and should -- have a local ground but not connected to the neutral at your home. What is ground (not neutral) in your house connected to now? A ground wire in the 200' service cable ?? (yikes ...;-)
Buying a 200-amp isolation transformer and paying for the resulting power loss from now to eternity does not seem like an attractive alternative.
The most authoritative electrical advice I can give you is: "Don't take electrical advice from a geologist" ;-)
I'm curious: Do you have a generator connected to the ATS?
... Marc
