All,
Thanks for the kind words. I'm just glad I've been able to give back to the community for once. Generally I'm the one getting IN on a deal. It is nice to provide it. Some thanks should go to Bucko, since he is the one that
a) first got one
B) gave enough positive information on it that it drove me to go out and figure out how to get contact with this company.
According to this:
You need to use the dielectric union between copper and steel. Neat, I learned something new!
I personally have CPVC, so...yeah, I was just going to put threaded ends on the 3/4 line and screw it in using some plumbers tape.
politics123, thanks for checking all that out, I also did not notice the reduced bore (I'm only interested in the 3/4" valve).
I have PDFS that I was sent a while ago, during my first few e-mails. I can post if people would like to see them to verify that the valves FIT your needs.
As was posted, I also believe that these are supposed to be food grade (hence stainless steel, vs. brass).
Also, as politics123 mentioned, they are all 2 way and 12VDC. the 2 way means you need to apply VOLTAGE to OPEN it, then apply VOLTAGE to close it.
New list:
drozwood90 - 1x3/4"
pete_c - 1x1"
politics123 - 1x1.25" ; 1x1/2"
dgage - 2x3/4"
gatorhwk - 1x1.25"
Kevin L - 1x1"
funat120mph (Adam) - 1x3/4"
mdesmarais - 1x1"
Total"
4x3/4"
1x1/2"
3x1"
2x1.25"
I'd like to ensure that everyone signed up for a 1" can accept the reduced BORE. I know how much that can affect your flow. I will go back to the vendor with the above list to get a rough idea on pricing. I will do 3x1" and 2x1.25" (I'm assuming at least one of you will switch to get the larger flow ball).
Personally, I like to try to avoid Paypal when I can, I like to use personal check. If any of you really do not want to do that, I will work out what the fees are, as was suggested.
Also, as I said before, you are more than welcome to order for yourself, to direct ship it to your house. I'm only suggesting we pool, since the shipping costs drop so much when I started to add more than 1 unit to the shipping box. PM me and I can give you all the contact information.
When Ms. Ava Gu gets back to me regarding the price on the above list (with 2 1.25" and 3 1" valves), I'll post the costs and try to figure out pricing per "person". Then, as I said, you can figure out shipping to your place from mine. 14514 Rochester, NY. If you want me to figure it out closer, I can try to do that if you want to PM me your address so we can get a real estimate of shipping from my house to yours.
--Dan
Edited for valve quantities as of post #68
