Abit IS7-E and spdif
electron
Administrator
Staff member
Does anyone have one of these boards? I use the SPDIF link to connect my HTPC to my Onkyo receiver, but the receiver isn't seeing a Dolby signal (i.e. Showtime broadcasts in Dolby 5.1 and the receiver will show this). Does anyone have any experience on configuring this motherboard? I do get sound, just not Dolby 5.1.
Squintz
I use the SPDIF on my ASUS board and i hat to go into the sound properties and enable it. I forget the exact process for doing this but i know it was off by default.
electron
Administrator
Staff member
I would assume the digital out is enabled as the optical cable is the only link between the PC and the receiver, and I have no problems playing sound except for it not being dolby 5.1. I configured the sound properties as well as I could, but it didn't make a difference.
smee
Is there a utility program associated with the sound hardware? I've used a couple motherboards that didn't give me configuration stuff through the normal drivers and control panel. I needed to run their application to configure.
See if the program you're using to play the files also has a setting somewhere.
electron
Administrator
Staff member
MCE has settings for Dolby which I enabled, and there is an option in the control panel dedicated to configuring this soundcard, but no luck.
TechTooth
I don't have any solid experience with this board, but I just had a quick look at the manual online and came across this (see picture attached).
This reminded me of a problem I had once with a DVD player that had both anolog 6 channel out and digital out. By default, it would only let 5.1 through the 6 channel (3 x 3.5mm stereo minijack) analog outputs, and the digital would only give out 2.0 (FL + FR).
This could be what is happening here too.
You may actually have to DISABLE 5.1 on your control panel settings (not the ones on MCE or it will downmix). This is because the board is doing the 5.1 decoding, when you actually want the receiver to be doing this.
Or you may (also?) have to check that the digital output is set to "RAW", not "bitstream/LPCM".
Don't know if this is relevant in this case, just thought I'd post my thoughts on the off-chance that it might help ;) .
electron
Administrator
Staff member
I can see what I did wrong , I have the card doing the encoding, which is wrong, thanks for clearing that up. Not sure if this will fix the issue, but will play with it some more.
