Mp333
Looking to add few more component to the build. Just wondering if I am overseeing any details. Currently I have the following installed.
[*]ELK-M1XEP Ethernet Interface
[*]ELK M1XIN 16 Zone Input Expander
[*]2WTA-B System Sensor Smoke Detector
[*]RRS-MOD System Sensor reversing relay/synchronization module
[*]Napco IQ Profiler Motion Detector (Came with the house. Need to replace them as they are not sensitive even on high sensitive setting. Looking for a recommendation for 20 to 40 ft.)
Looking to order the following for Phase 2.
			- ELK-M1GKS M1 Gold Control Kit with 28” Enclosure
M1 Gold Control Board - ELK-M1KP LCD Keypad
 - ELK-M1KPNAV LCD Keypad
 - ELK-1280 8Ah Battery
 - ELK-TRG1640 AC Transformer
 - ELK-73 Echo Paintable Interior Speaker
- ELK-M1DBH M1 Data Bus Hub (Assuming I can terminate stranded wire to RJ45 connector. Thoughts?)
 - OR ELK-M1DBHR (If I cant terminate RJ45. Current wires are bare…)
 - ELK-PD9 Power Distribution
 - ELK-SWG Glide for PD9
 - ELK-TRG1640 16.5VAC Transformer to power PD9.
- UPLINK 4500EZ
 - UPLINNK 4500CAB Serial cable for RS232 M1XSP
 - ELK-M1XSP Serial Port Expander for 4500EZ
 - ELK-SWG Glide for XSP
 - ELK-P624 Power supply/ Charger
 - ELK-1250 12V 5Ah Sealed Lead Acid Battery
