Ok .... I've been slowly trying to educate my non tech saavy brain .... but it's slow going. We start to build in a week, and here is what I've come up with for solutions to my various wants (note I believe they are needs but the wife disagrees!). I'd appreciate any comments you may have, and please correct me where I've misundersood a concept! FYI I've reviewed the wiring guide on this site (great tool!).
My House:
Three floors inclusive of a walk out basement. First floor, 2100 sq ft., has master bathroom and beddroom, office, great room, kitchen and laundry. Second floor, 1200 sq ft., has kids rooms, bathroom and bonus room. Walk out, 1400 sq ft., will be almost entirely a man cave, but has two bedrooms for future use. House will be heated through hydronic heat which is in turn run off of a geothermal system. Important to note is the fact that all things must have a very high SAF .... this means in particular that I must avoid having boxes all over the walls. So, with all this in mind I've come up with the following choices.
Control Devices:
I know this is a funny place to start, but I have a strong desire here which I believe will impact many of my other choices. I love the i-touch/i-phone's and would prefer, if possible, to use same to control my home automation. I see the i-touch as being the ultimate replacement for all my remotes! The screen is small, but I feel with the cool little magnification tools they have is more than useable. Plus it's wi-fi, so it should work anywhere in the house. As time goes by I see more and more companies jumping on this bandwagon, and for my wife it's hard to fault apple from an ease of use perspective.
Whole House Audio: (sources are MP3 collection, Internet Radio and maybe HD-Audio via DVD)
I want centralized distribution, not interested or more importantly allowed to have receivers in each room. I want ten zones. Master bedroom, master bathroom, deck, shop, kitchen/great room, kids rooms, office, downstairs rec room and bathroom.
I'm stuck between a few options.
a) Nuvo essentia which I believes allows you to expand up to 12 zones. Pros: Energy efficient, built in amps Cons: Nice wall plates, but another thing to add to the wall. Not sure of the quality of the built in amps. Can this be controlled through i-touch? Also, seems common for people to pick this up off of e-bay for a decent price. Can someone comment on the built in amp quality. Would I be better off buying seperate amps to go with this system, any recommendations?
Breath Audio .... from what I've read very similar to Nuvo but without the fancy keypads. Cheaper .... but maybe not so much if you can find a good deal on e-bay.
c) Speakercraft. Looks similar to the NUVO ... but may have nicer keypads. Has an i-touch app .... but seems ridiculously priced.
d) Squeezebox(s). Pros: Cool remotes ... may have increased fuctionality in the future Cons: I'm not sure this setup could work for how many zones I want ..... could I still keep the boxes centralized.
d) Speakers .... open to suggestion, but I'd like good quality (and easy to install!).
Ideally, I'd like to just run my speaker wire back to automation room and then control everything via RF or wi-fi remote. Can't see wanting to get off the couch to walk to a keypad everytime I want to change a source or song.
Whole House Video: (sources Sat TV, PS3 and content on the computer)
What a mess. The only solution that seems to be universally hailed is Kaleidascape. For me this amounts to champagne tastes on a water fountain budget. Not going to happen. This is an area I'm very confused on, but I'll give it a whirl. I need to be able to watch the same or different sources in different rooms.
Satellite TV: I think I need a box per room assuming each box only has one tuner which means I need to split the incoming signal someway without degrading picture quality since they are HD sat box's. I would imagine it's better to have the box' de-centralized and run an HDMI to each TV? That way I only need one RG6 wire from the control room to account for the the satellite.
Playstation 3:
Mainly will be used for home theatre which is downstairs, so doesn't make senses to distribute anywhere else.
NAS/Computer content:
My plan here is to have a 3 or 4 popcorn hour boxs in the control room and run a hdmi cable off of each box and run it directly to a corresponding tv source. Will this work? Can I run the TOSLINK connection into a AVR so that I can have sound come thorugh my speakers?
Lighting:
Thinking about using on-q, but the wall plates aren't exactly sexy.
Security:
Elk panel. I think I can run my smoke detectors, HVAC (ecobee, looks cool and it's Canadian!), door/window sensors, CO2 detectors and possibly my cameras. From my understanding of the wiring guide I can get away with one wire to most of these items. Whether it be security wire, cat 6 or what have you.
I will be buying POE IP cameras .... from my understanding I only need to run a single cat 6 wire to account for this? This would in turn run into some kind of a special network box?
Wiring:
At each TV location I'm going to run 2 cat 6 wires and four rg6 (I think this will give R,G,B + sound). I will also run an HDMI cable from the control room as well as one from somewhere within each room to accomodate the sat tv. Are there any faceplates that accomodate, or do I need seperate ones. Speaker wire will run directly back to hub room.
I'm sure I'm missing a lot, but at the end of the day I'm hoping to end up with one control device in each room that controls all of the above. I was thinking of using mainlobby as a front end, but CQC seems great as well. Not asking which is more powerful, but rather which would be the easiest to get up and going with.
Cheers
My House:
Control Devices:
Playstation 3:
Lighting:
Security:
Wiring:
Cheers
