I am converting over to an HAI Lumina Pro from my previous Homevision system. I have a Stanley Garage Door Status Indicator module that I sent Extended X-10 commands to which controlled the LED's. One of the Homevision users decoded what needed to be sent to do this: (can't post links yet)
For example, to turn all the LED's green and the module is on House Code A, you send the following Extended X-10 Command:
House Code = A
Unit Code = 9
Command = 29 (decimal)
Data Byte = 112
The Homevision system allowed you to send this type of extended command, but I am not seeing a way to do it with PC Access in the HAI system.
Since there is an "Extended" unit type, it seems like I should be able to send this type of command.
I looked at the possibility of sending a "Message" to Serial Port 6 (the TW-523 I hope), but not sure if this is just sending ASCII text or not...so have not dug into that further.
That little module is just a nice, cheap way to show the status of something, and plug it in where ever convenient.
Anyone know if I can somehow send the Extended X-10 command shown above?
Thanks in advance!
Matt
House Code = A
Unit Code = 9
Data Byte = 112
Thanks in advance!
Matt
