drvnbysound said:You mentioned above that you are planning to use the Altronix to power the entire system... I assume this to mean both the house components as well as garage components.
There are also posts above asking about installing it in the house vs. the garage. I didn't see anything clarifying where you have decided to install - I assumed the house due to temperatures mentioned.
Yes but the altronix isn't installed yet, it is planned as an upgrade to rule out any power supply problems and for future expansion. Right now the house runs on the controller ps with the exception of the xep which runs on a p1216 as you advised. The garage runs on the p212s.
Mike.
Correction to the above....the twa runs on the p1216.
