The Linksys Firewall/Router enables the internal “LAN” side of your network to be isolated/protected from the external “WAN” side of the Internet. Thus your home will only have one external IP address that is shared by all the internal computers in your home. When you set up a web server on a computer on the LAN side (such as Homeseer) you select a port number to run that web server on.
When you need to access this web server from an external (outside your home) internet connection, you need to know the IP address of the Linksys Firewall/Router, plus have port forwarding set up so the Linksys box knows what computer to route the port number request to.
The Linksys box should already be connected between your cable or DSL box and your computers. All of the below instructions should be run on the internal LAN computer that you plan on running your web server on for simplicity. It is also assumed that no modifications have previously been performed on the Linksys setup menus.
Click here to view the article
