CT Droid
CT Bot
The guys at Domobec have been very busy. They came up with a product, Moonshine, which replaces an actual light switch. It reminds me of the RedRadio product line (1-gang touchscreens, which were basically mini-monitors), except this unit has actual processing power and runs CE, making it compatible with several home automation packages out there (currently supports HSTouch). While the specs are not final yet, they look interesting so far:
Read more to see a video of it in action.
View the full article
See this thread for comments and updates.
- 32-bit 145x300 LCD
- Unit will fit in a single gang junction box, so you will be able to fit 2 displays in a dual gang junction box, etc.
- Ethernet connectivity is provided through an integrated Wi-Fi chip.
- The final version should be compatible with most decora plates out there.
- The MSRP will be around $149.99
- Connects directly to your 120V power.
- Will eventually come with software so you do not require HSTouch.
- They are expected to be available sometime during the last quarter of 2009.
