Hi, I'm new to the forum and to automation. I just moved into my condo and wanted to go ahead and set up home automation. For software, I'm thinking of using Indigo4 for Mac and Indigo iPhone app to help control while away from home.
I want to be able to control the following:
- thermostat
- curtains (4 sets)
- entertainment center (tv, sound bar, and satellite box)
- lighting (lamp, and possibly kitchen light switch)
- bedroom fan
I've been looking at Insteon equipment to help with the hardware side. Any suggestions on what hardware I should get? I would like to be able to do most of it wireless. I know I'll probably have to install a wired switch for the kitchen light and bedroom fan.
Thanks for the help!
I own three Mac in my house and use them for about everything EXCEPT automation. Really, you can buy a pretty good PC for about $300 today, so if you are even remotely serious about automation, I'd go that route. Actually running Windows Home Server on it is a good idea. I actually use two PCs. One for Windows Home Server and one for automation, but these two could be combined. If you go the HAI route, there is a product from HAI called Web-Link3 which is pretty cool. It runs on the Windows Home Server and lets you access your system from the web, iPhones, and Blackberry's, lets you monitor an network cameras in your home, and it can send you e-mail alerts when problems occur. So if you go the HAI route, and use that for control using UPB, and its a security system as well, add a Windows Home Server with Web-Link3, and you have a pretty capable system, and you get a file server in the process.
I have gone further than this with CQC and lots of other extras, but adding that on in the future isn't a problem. you will find that the software control program is cheap. Where the cost will be will be the light switches, and security system wiring and installation. This is why, if your going to do all this, you might as well go to a PC for many more options. If you just want to play with a few switches, and impress your friends when they come over, by all means, a Mac and a few switches can easily do that fine.
Most people go either in one of two ways after they install a small automation system. Either move on and it never gets used again, or they rip it out, start again from scratch, and get a system that meets all their needs, but I will warn you, this is usually a multi-$1000, many year endeavor.
