mtwalsh367
I must be doing something right. My wife and I are looking for shades for a bunch of windows across the back of our house and she is asking me how we can make them open and close automatically. I guess all that work with integrating lighting automation with the security system is deemed a success (thank you Insteon and Elk).
We are looking at hunter douglas shades, because we have always liked the brand, and these have a power rise option. Essentially a battery powered motor that can be controlled by an IR remote aimed at the top of the shade unit or a remotely mounted IR reciever. There is also a manual push button next to the IR receiver in case your remote is dead.
So I am considering my options for automating the shades and am looking for input from anyone that has some experience or insight into options that are preferable.
1) I can pretty easily hard wire relays (already use relays with the Elk to automate open/close of garage door) from the M1 to jumper the wires on the hard wired switches on the shade units. I have to believe these push button switches are just a simple contact switch. This will allow me jumper one relay to a series of shades that I want to open and close at the same time (4 windows together in a bay window, etc). advantages are rock solid operation and control from the M1 rules and eventually from Insteon controllers once the Elk adds support for recieving Insteon group commands. Also, the handheld remote that comes with the blinds should still function. disadvantages are running wires.
2) I can add IR support to my automation system and control the blinds through IR signals. advantage of this option is not having to run wires to the individual shades to control them. The disadvantages to this option is the added expense of adding IR control to my system and at this point I don't fully understand what I need to make this work. I am looking into some PC based automation to enhance my M1 capabilities but I don't know if that helps with an IR solution or not.
3) I understand that Insteon is working on their RF products (supposed to have been released in 2006 but there are many questions floating around as to what is going on with Smarthome and the products they had promised with Insteon for 2006 that have never materialized). Even if Insteon adds support for RF I don't know how this helps me out if I have IR controlled shades. I have alot fo learn about IR and RF automation.
Thanks in advance for any recomendations and also links to other good references that will help me learn more about IR and RF automation.
Matt
Matt
