Desert_AIP
I have started playing with AS in preparation for adding two 5.7e touchscreens.
I am trying to get my layout set while I have some time on my hands.
Unfortunately I can't connect my laptop with AS to the internet right now so I can't update beyond the version I am using.
And I can't connect to my controller to run the simulator, I thought I should be able to do it offline.
I'm running version 1.0.2.87 and see some weird behavior.
I looked on HAIs developer site and in the knowledge base but can't find the current version release notes for AS just PCAccess.
I can't change the format of any clock. I can select and save a different format but it doesn't change on screen.
The Security panel keypad is blank and I don't see an area in the general settings for the screen to add images for the number buttons.
Even if I add a new one.
I can import screens from the template that do have the security button images, but it is imported as an image so I can't do anything with it.
When I add a container and right click there is no "Edit" option available (read about that command on the HAI Forum).
I looked in the image file folders and the fire, police, etc icons are not in there. The Button Bar images are in there.
When I want an Object to be transparent, I have to select true, then navigate to another page and back for it to actually appear transparent on the screen.
Also I see menu items but when I search for them there is nothing in the help file explaining them.
So I'm wondering if it is a software version problem, or I'm just not doing something right.
I followed Worthignton's advice and started with a template rather than a blank.
This is really frustrating not being able to update the software.
