I am a current TED user transitioning to multiple Brultech ECM-1240s for more granular monitoring.
I started with my subpanel since it is easier to get to and install everything. The sub-panel is 100AMP being fed from a 200AMP main panel. I am monitoring the sub-panel using Micro 100 CTs on Channel 1.
On Channel 2, I am monitoring a 60AMP breaker that goes out to a hot tub (through a SPA disconnect box mounted outside). I am monitoring this circuit with a pair of Micro 80 CTs on Channel 2. The CTs are hooked up as in this picture from Brultech's site:
I also have the two CTs facing in opposite directions per what I believe the manual is telling me (I couldn't find a copy online).
With the SPA going full blast (two pumps and a heater), the readings I am getting with the Brultech don't make sense. On the 60 AMP circuit, I am getting a reading of 90 AMPs. Obviously this doesn't seem right. I would have expected it to be right around 50 AMPs based on the spa manual.
Here is what the realtime monitor looks like with everything on ths spa turned on:
I used the CT Calculator tool to get what I believe are the correct settings:
I have both white wires from the CT going to the "DUAL terminal and both black wires going to the COM terminal with a 7.87 ohm resistor in between.
Here are the settings entered in the Brultech Software:
Does anybody have any ideas on what I am doing wrong? Or do I just not understand the results that I am seeing.
The other channels "seem" to be okay based on turning lights on and off (with known wattages), but I given the results I'm seeing with the SPA, I'm not sure I can trust any of the channels.
Scott
Scott
