I have an Elk M1G. Having trouble getting zone types 4 and 5 to cause an alarm when the system is armed. Both zones are motions with normally closed contacts. I arm the system and trip a motion. Nothing happens.
If I log on with RP while it is armed and checked the status, I see the voltage for the zone go from 7.3 volts to 12 volts. I never get an alarm, though.
If I change the zone type to a 03, then it trips instantly. The definition is 05 and the zone type is 0. EOL resistor is wired correctly at sensor. Attributes are bypassable and swinger shunt. I've armed disarmed between testing , so it's not swinger.
What am I missing?
What am I missing?
