In our latest firmware 3.02.16, you can actually set VAR or OP from 3.02.16 board to older or same firmware board, through PLC programming new WEBSET command.Hi !
Ok, I have to find another soulotion to my desire to have two ore more WC to interact.
Is there a tiny and wery low on power PC that runs Windows ?
/s
It works now, Thanks LarsKSeems like I found the bug.
If you have a counter issue, download and install v1.4.6 again. (silent upgrade)
Hope this helps!
ChubRock1 said:LarsK - Great tool, I have been using it for many months on shorter projects now without any issues, but I noticed today on a longer project I am doing that it no longer seems to be writing to the save file? It is still collecting data (I have it going every 30 secs) and when I tell it to save to a file it seems like everything is fine, but the file is 0kb and when I open it, it has no data in it. I am at about 35,000 lines in the tool, could that be a problem?
I would just stop it, close and restart the program, but I have been using it to track information and if I do that I will lose the last two weeks of info which I really don't want to do if I don't have to. Any other thoughts?
Thanks.
Thanks.
Tschmidt said:LarsK, now that I've finished up the greenhouse and wood heat controller I wanted to play around with logging and stumbled upon your spiffy program.
I've downloaded the latest version v1.4.6 running on XP pro.
1) Perhaps I'm slow but I cannot figure out how to log more than one item from the "Choose Data" page.
2) What is the purpose of the "Values" pulldown?
tks - Tom
LarsK said:You should be able to make something like this:
