trmitche
Hi everyone - I love this board and I'm going to drive you all crazy - I’ve been hooking up my new toys (M1G/XRF/XSP/XEP/DBH/Listen-in kit) over the past week, and basic security is functional and reliable (incidentally, without a single *wired* sensor of any kind). It feels very nice to have – my non-techie wife is even excited! When we bought the system from Martin at AO, we told him that (to start), we wanted to integrate only basic lighting control for our 4 outside lights, for security purposes. He sold us on HAI UPB. We bought the serial Computer Interface Module ("CIM" or "PIM"?), and 4 600w dimmers (and Martin threw in a lamp module for free – thanks again man!).
I used the lamp module and UPStart to test things out, and once I set the network ID in ElkRP to match the one in the CIM, I was able to plug the CIM back into the Elk and control the lamp (via a rule) right off the bat, which, incidentally, feels sooo good the first time it works, for a noob like me anyway.
On to my question(s) – I had assumed that once I plugged the PIM into my PC serial port ONCE (to set up the network) that I would then be able to hook the PIM back to the Elk via XSP, and leave it there, adding new devices as I go. But apparently, UPStart cannot see the CIM when the CIM is connected through the Elk XSP. I’m planning on adding those 4 switches one at a time - as time allows – so it kills me to think that I have to remove the CIM from the Elk and connect it to the PC EVERY TIME I want to add a new UPB device? I really hope I’m missing something there.
I would just dedicate a few hours to add all 4 switches at once, to make this a non-issue, but these outside lights all have multiple switches to turn them on and off, so I have to install quite a few three-way switches while I’m at it. In addition, I have to install regular, non-controlled paddles on all the other light switches which share the same gangs as these 4 lights, to prevent having different switch types in the same gang – the wife won’t allow even a temporary loss of the bezels, and I don’t believe I could easily find a four gang face plate with Switch|Paddle|Switch|Paddle configuration (or similar). This brings me to my other question. For the three way switches, do I have to buy the HAI “slave” (Auxiliary) paddles, or can I use normal 3-way "dummy" paddles from Home Depot? Eventually all my lights will be controlled, but I suspect that, in the interim, this is going to be a major inconvenience for me, any way I slice it – unless anyone here can share your similar experiences and how you dealt with them.
Sorry for the long winded post with more comments than questions, but I enjoy explaining the details right now – I am absolutely addicted to this stuff and it’s only been a week. Thanks!
PS – It shouldn’t matter, but since I mentioned the XEP as part of my setup above, I will add that it is not hooked in yet – I’m just using the main Elk serial connection to the PC for now – another reason why moving the PIM back and forth is a pain – I only have one serial port on my PC. The reason I don’t have the XEP hooked up yet is because I’m waiting for the phone company to come out and hook the Elk into my phone line, as well as add a phone jack in my wiring closet for the DSL modem/router. Then I’ll something to plug the XEP into. Right now the DSL modem is temporarily on the other side of the house.
