mustangcoupe
Watch Ebay, I just got a used Rhino 3000 for 45 bucks.... now the heat shrink is 20 per 6 foot length, I will find out how far it will go once I get it all in about a week or so
I don't think this is a good idea. Since each source will be located in a single location, you're going to have patch cables of all different types running all over the place, crossing each other, etc. It can get messy enough just keeping the keystones for a specific use together, i.e. all telephones in one panel, all network in one panel, etc. In my house I have all my cat-5 in one panel, thus mixing phone and network together. Now I wished I hadn't, and I haven't done it on any installations since then.I also plan to group the keystones by room
I wouldn't worry about it. Just make sure the plumber is done with all the plumber work BEFORE you install the elk.my wiring room has a drain pipe and a water supply runnign over it
what size heatshrink should i get for RG6QS and Cat5/6? .25"?? I assume this is the diameter before shrinking..
Seems that the company Esselte (Pendaflex in the U.S.) makes the D1 cartridge labels for Dymo, and also sold their own brand of D1.
Now they don't anymore. I guess Dymo got their act together.
(Edit - Dymo is a subisiary of Esselte http://global.dymo.com/enHK/Privacy/default.html)
Edit - the Rhino 3000 can take heat shrink tube labels, per the sales sheet
http://global.dymo.com/img/compel/Xo...br1MSMu69P.pdf
Heat shrink tubing is even more expensive, ~$25-30/5 feet, but can be used in place of other heat shrink tubing, i.e. when you need to cover a soldered connector, FWIW.
Rhino 3000 can take the 3/8" + 1/2" heat shrink labels, but not 3/4". I don't know what size would be necessary, for cat5, rg6, rg59, zip cord, 22/4, 18/2, hook-up wire...
Edit#2 - cableorganizer.com has a good breakdown of the Dymo labels, and printer compatibility.
http://cableorganizer.com/dymo-replacement-labels/
data sheet for recommended cable diameters, for heat shrink labels, page 7:
http://images.cableorganizer.com/dym...Tapes-info.pdf
I think cat5e is ~5 mm in diameter (0.189 inches per Belden data sheet), allowing the 12 mm (1/2 in) heat shrink tubing.
3/4 in (19 mm) heat shrink tubing tape is not compatible with the Rhino 3000, so I guess I'll use the standard nylon labels for coax.
RG59 is ~0.233 in (6 mm), and RG6 ~0.274 in (7 mm).
I should have put in a disclaimer - I don't have firsthand experience, just repeating what the Dymo info sheets say.
Maybe they're trying to sell more of the 5000 labeler?![]()
Dymo says the heat shrink tubing reduces to ~1/3 the original size - that sounds like a maximum amount of shrinkage, but I would think that is, indeed, a maximum.
I'll have to try it, when my 1/2" heat shrink labelled tubing arrives. Will post back then.
Thanks for paying attention, Mustang.
