The distance between the OnQ and the M1 do not permit this exact setup. The rjset's cable is too short and not worth snaking inside the wall.
What's interesting is if I consider what you're saying, you're telling me I don't need the modular jack part of the rjset, just the handy cable. This is because I've already got the jack I need in the OnQ.
If I follow what you're saying, but deliver the rjset cable's wires to the M1 using my runner cat5, I think I first need to correct a few things on the OnQ. First, the telco line in doesn't go to the line input, it is spliced to the runner. The wire returning from the M1's house line terminals is punched down into line input.
This is how I think I fix my OnQ:
1. Pull the house pair returning from the M1 off the line input punchdown
2. Break the splice of telco inbound to runner
3. Put telco inbound in its proper place on the line input punchdown, making the line input punchdown now fully straight wired from the telco inbound
4. Wire an rj45 plug using the runner cat5's four wires and the proper pins 1, 4, 5, and 8
5. Plug that into the OnQ rj31x
6. Flip the switch to off to interface with the M1
This operates on these hunches:
- You need a proper and plainly wired line input before you mess with the rj31x
- When the security interface is engaged by the switch, the hot pair from the line input punchdown is routed through the rj31x over to the M1 and if the M1 permits, the house phones receive an active line returned on the R1 and T1 wires into pins 1 and 8 on the rj45 plug
- The circuit with the security switch bypassed is line input > zones. The circuit with the switch engaged is line input > rj31x > runner > m1 > runner > rj31x > zones.
One concern I have is the second phone line once I flip on the circuit through the rj31x. Another is the relationship of the rj31x pins and the punchdown positions. It's too late for me to dig into T568A right now, but if the zones are going to work right I need to pinout my runner's rj45 plug right. Probably the part of this that I know least is how to be sure the two phone lines work in both switch positions.
Thanks for your help so far, Steve. I've been shelving the phone distraction so I could do the main job, I did all the zone wiring today including my renewed relationship with my motion sensor. Turns out the motion sensor is the 33rd wire, so I had to pair up a couple of windows since I can't justify a second M1XIN and second cabinet for one zone. I had hoped to have one sensor, one zone purity but I need a motion sensor over my home theater gear more than I need purity.
Fired the rig up today. It was a joy to hear M1 try to speak through a 15 cent siren horn in the old Ademco speaker. Swapped in the speaker from the M1 kit and the wife goes "oh great, another thing that talks. They're all going to talk about us when we're away."
M1XEP, ELK-RP and a few hours config, HomeSeer, UltraM1G, and I can move on to whole house audio or Bitwise Controls IR with HSTouch depending on mood and coin toss.
