I've really got to recommend the Rain8 controler from
WGL designs I've got mine hooked up and the ability to control it from a computer or an X10 remote is really, really nice. You could probably build what they are selling if you have an EE degree or are really handy with microcontrolers, but their solutions work and is nice and flexible.
I've done mine in-ground for around $1000 for a 7-zone system, some of which are low-pressure driplines. A couple of key things I learned from doing this:
- send in your lot drawing to a couple of the big sprinkler companies to see what they recommend for sprinkler head placement. Their pipe layout and recommendations are way too conserative, but getting a good idea on where to put the heads is half the design.
- Do lots of planning up front on all the little parts you will need. Also, at least in my area, Lowe's section on pipe-parts is much better organized than Home Depot's. I spent probably 6 hours on 2 trips at Home Depot finding all the little pieces and bits that I needed!
- Use 1" pipe rather than 3/4" pipe. Much better water carrying capacity so you can do fewer zones. Remember that more zones = more money. I also think that 1" is actually easier to work with, but I really like PVC pipe for both water and for making frames for other projects
- A trencher can be rented, and while difficult to use, is much better than digging everything by hand. I rented one for a day at a cost of $230 to do all my trenching. And while it was about a 1/4 of my overall cost, it was well worth it given that my soil is very clay-like. Get some friends to help with this bit as it's a monster to use, but very effective.
- It's a big project. If you plan ahead, you may be able to install it in stages with the possible exception of the use of a 1-day trencher rental. For example, I installed everything with the wires, but didn't add the controler until the next year. Because I planned ahead and put the necessary wires in the ground, I was able to add to it later instead of either going back and adding wires or being forced to do it all in one shot. Be prepared for your lawn to be torn up for a nontrivial length of time (months even!)
My sprinkler photos Which gives a rough sense of what the trencher can do and it's got some shots of some of the layout...
Good luck!
- Mike
