HAI_fjh
Since all 3 sensors are not working, my thoughts go to what is common to all 3. Starting with the basics, please check the following (with the panel powered down):
1. The Hardwire Expander is properly connected via the 20 pin ribbon connector.
2. The addr jumper in the upper left corner is set to 1 (first 2 pins |:::lol:.
3. The sensors are connected to the + terminal of Z14, Z15 and Z16 on the board. These are located on the top row, right side.
A VERY common error seems to be connecting to the wrong row on the Hardwire Expander. I guess we should have made the top row left side Z1?
Any how if everything appears to be connected properly, I would next verify the basic operation of the Hardwire Expander by putting a resistor across one of the unused Zones. from your screen shots it appears that Zones 28 and 29 are not used. Temporarily name then and put a 1K resistor across on of them. Go to the status page in PC Access and verify that the zone with the resistor shows "~147 secure", and the zone without the resistor is reading "0 not ready".
NOTE: Temperature and Humidity zones are only updated every 30 seconds (I believe) so the readings may not appear for a minute or so after the panel boots.
