Sacedog
So my alarm would not arm today, saying that a zone was violated. After doing some troubleshooting, I figured out that the powered contacts (motions, glass breaks) were only getting 6.5 volts from the Elk-624. The jumper was still set to 12V, and I have not touched my system for months.
I happened to have a spare Elk-624 sitting around, so I replaced it, and voila, I had 12V again. I armed the system and went to work. About 15 minutes later, I received a notification that my alarm had been activated. I disarmed it remotely, and continued on to work.
When I got home this evening, I went to check the voltage, and it was back to 6.5 volts. I then thought it might be the Elk TRG-1640, so I replaced that (I happened to have a spare of those too). Once again, I had 12V. While I was in the wiring closet, I was cleaning up, and after about 10 minutes, I noticed a "hot electrical smell". I went and looked in the can, and noticed that the Elk-624 was VERY hot. The cooling fin at the top of the unit was so hot, that when I licked my finger and touched it, it sizzled. I woudl not think that is normal, but I thought I would ask the question here.
Should the Elk-624 get that hot? If not, any ideas on why it is? Do I have a short somewhere? It seems odd that the 624 woudl get that hot...none of the wiring between the 624 and the 1640, the wiring from the 624 to the Elk (for the common ground only), or the wiring from the 624 to the PD9 was hot at all.
With the smell, I did not feel comfortable keeping the 624 powered on. I have a spare PD9 and battery that I could swap out, but I do not think they would help.
Thanks for any input.
