Hooked up the Elk930 to the M1G and not getting any reponse. Not sure it is hooked up correctly. The Doorbell had wiring running between the drywall and framing so I could not trace the wires that way. The doorbell unit has 3 wires coming in to it. Went in to the attic and found 6 wires coming out. Thought I had spliced the wire going to the door bell but the reading I get is 14V and then drops to 5V when the button is pressed. And 31mA and down to 16mA when button pressed. If I tie into the other wire I get no voltage or ampurage change, but the doorbell will not work if disconnected. What is wrong here? How can I figure out which wires to tie in to?
