Frank,
No. However the way elk works is that it receives a text message from the w800 rather than an on or off.
ELK has vitual outputs the same as virtual devices in HS.
So the first rule I have setup is that everytime the "text" is recevied then turn output 100 on and vice versa for the off equivalent.
Then there is another rule (time based). every 30 seconds announce "garage is open" if output 100 is on.
The confusing part is that one would not know if the text received is a hearbeat message or an actual change in the state of the DS10A so don't know how that would work.
regards,
regards,
