apostolakisl
Thank you for wire-guage specs. I also took a more thorough review of the specs: separate power supply required.rfdesq said:18 gauge 4 conductor wire is specified.politics123 said:Can I power this through a Cat5, or do I need a larger gauge wire?
I agree with Spanky, high-quality vavles are expensive. However, manufacturers make similar products for different OEMs. Take a look at the following one and tell me if the picture looks familiar
http://assuredautomation.com/101/buy_101.php
The 1" wide, 12V DC version quotes out at $309.
EDIT: A 1" AC version is $286
I read the specs on this one and it says it is a brass valve. The Elk one says it is stainless steel. It may be made by the same company but it does appear to be a different valve.
