ELK FOB-Register with system
waltmoe
Greetings: I am new to this ELK alarm stuff and am having diffuculty registering 2 ELK FOBs into the system.  I have the system built out on a workbench testing all componets, sensors etc prior to install.  I did configure a wireless sensor that could be used for a door or window and it works great.  I just cannot seem to find where to configure the 2 ELK FOBS into the system. Thanks for your assistence...
Are you using the keypad to enroll the sensors, or RP?
The procedure for a keyfob is similar to a window/door contact, and since you are able to enroll one, that's a good sign that you are on the right path.
If using the keypad, I assume you are able to get to the step where you select Lrn to enroll a new sensor, right?  Then you need to press the Lock and Unlock buttons at the same time.  At that point, the keypad should chime and display the code id of the keyfob.  Are you not getting the chime and code-id?
When you press one of the keyfob buttons, do you see a faint flicker of the LED?  It's best to check this in a dark room, since it isn't very bright.
Got it.... Like I said I am new to this... In installed each FOB as a wireless device, they now work and work GREAT..... Thanks
