I have an ELKM1Gold, two M1XSP's, an M1DBH and the ethernet module.
The one M1XSP is tied into my AMP thermostat (via the M1DBH) and works great.
The other M1XSP is updated with the correct firmware for Insteon. As far as I can tell everything is set correctly for the Insteon on the XSP.
I have six insteon devices set up, I have defaulted them all to make sure nothing is conflicting. They are all set up as serial port, and dimmer.
I have defaulted the Smarthome V2 Serial, which is tied into the XSP.
I've (as far as I can tell) followed the instructions on how to enroll each device, and setting the lighting on, to the 256 at the keypad.
The M1XSP never seems to blink the right way. It acks like it never sees anything.
I have used both XSP's in doing this, updating the firmware each time, both are running off the data hub.
It does not do anything.
Any ideas?
Any ideas?
