dBeau
I have two garage door openers. The newer one is the one I expected problems with. Turns out replacing the lighted button with an Elk relay is no problem. A project for another day is use a couple more relays along with the capacitors from the original button to control the lock and light features.
But this is a story about the old opener. It uses a standard non-lighted door bell button. What could be simplier. After testing by touching the wires together all checked out fine. So, I connected it to a relay and tested it. No luck! ...but the relay was clicking and the led was blinking. Turns out, that a "long press" will activate the light without opening the door, while a short press will activate opener. The nice bit is that I finally understand why my wife has had such trouble getting the old button to open the door. The bad is that I cant figure out how to get the elk to close the relay for less than one second.... and one second is considered a "long press".
I ended up hacking my remote and used the elk relay to "push" the button. This works but I'd really rather keep the remote in the car! Any suggestions?
