apostolakisl
Unless i'm missing something, i did it to code which is summarized here:
http://forums.mikeholt.com/archive/index.php/t-57182.html
The key is the low voltage i have running between the buildings. Network between them is over fiber, but the elk bus, coax, and phone would be considered paths.
-brad
Code doesn't care about protecting you from lightening transients. The concern with code is fire and electrocution, not your delicate electronic gizmos.
If you have a grounded LV device in one building that is connected to a grounded LV device in the other building, and each building has its own ground, then an induced current can travel through your LV stuff, even if the two grounds are tied together. Basically you have two wires running in parallel (the wire tieing the grounds together and the wire for the LV device), and some current will go through both depending on the relative resistances.
If you have to have a LV device in the second building that is connected to a LV device in the first building, consider powering device in buidling 2 from building 1's power (like poe).
Or, consider isolating the two systems as neurorad suggested or by using rf com.
