Bench testing my WSV so that I can fully understand how it operates in preparation to install it. For now, I have it hooked up to the M1G like it is shown in the documentation, i.e., output 3 and VAUX.
When the M1G starts up, it sets all outputs to closed. That means the WSV will be closed (or remain closed) at system startup. How do people using WSV's controlled by an M1G handle this? Do you have a startup rule that opens the WSV a minute or two later? Before restarting the M1G, do you make sure nobody/nothing is using any water? Seems to me that a little convenience is being sacrificed for a little more protection.
Alternatively, does anyone have it wired opposite of what the documentation says, i.e., white wire to N/C and red wire to N/O? That way, the WSV would open (or remain open if it already was) at system startup. The downside I see to this approach is that if the WSV was closed prior to the system startup due to a water leak, when the system restarted, it would open and potentially cause more water damage, until the leak was detected again and the WSV was told to close. So no inconvenience, but potentially less protection and more damage.
In my case, the WSV will ultimately be controlled by a remote M1XOVR expander and powered by a separate PS, so the system startup can take a minute or two. And I understand that the M1G is seldom restarted, but just curious if anyone has strayed from the recommended path.
Ira
Ira
