KentDub
I'm looking to purchase a M1G to be the central controller for my house. I write .NET software professionally for large enterprises - so naturally when I found out that some people have written .NET programs to interact with the M1G I've been drawn to it. I already run a home server (Windows Server 2008 Standard) that is on 24-7 - so no issue there. What I would like to do is to use the M1G for everything security, and 'offload' the home automation tasks to a custom-built .NET application running on my server. The primary drivers for this idea is from what I've read the M1G seems to have very (very, very [hey, I am a programmer]) limited rule capabilities (specifically no nested statements or OR conditionals).
Am I out of my mind for trying to do something like this? As long as (via the ethernet module) I can poll and/or get the M1 to broadcast events to the computer - as well as be able to send commands to it I should be OK. This, of course, also requires that I can locate a protocol documentation sheet (RFC of sorts).
I was also looking into installing a UPB lighting system as well, but was very disappointed when I found that the M1G can become out-of-sync with the state of the lights. From what I can figure out from the threads, it seems there is a way to have a computer correct the M1G. (Most people were compaining about the proposed solution because they didn't want to run a server 24-7 -- however, I didn't really understand what all is necessary for the solution). Since this is a retrofit project, will UPB work (correct status of the loads is very important to me)? Or should I just bite the bullet and start cutting the drywall and go with a wired solution?
Also - I don't have a single 32-bit computer in the house... Am I going to need to install a virtual machine to communicate with the M1G (even if only for setup)?
Any help locating the protocol documentation and suggestions/comments would be greatly appriciated.
Thanks much,
Kent
Thanks much,
Kent
