Link?Looking into the Fit2-PC XP version, soon to be released. I want to use it with CQC, automation only not media server, and like the 6 watt power consumption. Thoughts?
I think that is awesome.Thoughts?
Based on your expertise as displayed in IVB's last CQC webinar, I'm definitely going to be picking your brain on this. The Fit will be available from Amazon.com very soon.I've been waiting for this thing to come out for a while now. I'm also going to use it for my main cqc server and planning one using a external hard drive to store my media on. The only problem with the FitPC2 that the diskless version only comes with the smaller chipset and no wireless. I wish you could get it with the 1.6 chip and wireless with no HHD.
http:// DVI-I Dual Link Male to HD15(VGA) Female Adapter (Gold Plated)Use this adapter to change your DVI Connector to regular VGA Connector.
Some video cards have a dual display capability. Use this adapter to allow dual display.
There are two types of DVI Connectors: DVI Analog and DVI Digital. If your DVI is digital, this DVI Adaptor will not work. Please check your DVI Pins carefully whether this DVI adaptor will fit in.
For example, if you have ATI Radeon VE Dual Monitor graphic card, you need this adapter to change one of your DVI connector to VGA connector to enable your Dual Monitor capability.
I just did some more research. It is only digital. Standard DVI to VGA converter will not work. A USB to VGA adapter adds another $75 to the mix. Is the solution to set the box so it just acts as a server and use your desktop or laptop to interface with the box? Am I even close?The question is whether the DVI output in this piece of kit contains just digital.
I would be hesitent to go with the Atom for CQC work. Tom's has done a few articles on the Atom and they all say with anything over internet viewing and email checking you will be waiting on the CPU. I just got CQC too, and I am going to be running it on my WHS that's an old X2 3800. I'm looking to run a touch screen for the CQC interfaces, and I plan on running them off a custom uATX I'm building (see my blog if you'd like more info). I wouldn't think the Atom would have problems running the client side of CQC, but running the backend I think would make it keel over.
--Jamie
--Jamie
Not to CQC threadjack here, but why do you think the server has a higher load than the clients with CQC? I would guess that the client side is more CPU intensive than the server, assuming that the client is displaying nice graphics and that the server is just talking to a bunch of devices. On an atom I'd think the server could be serving up MP3's over the net and still be just fine. Do you have any data or specs that indicate that an atom based solution won't work?
