Get rid of Insteon and switch to Zwave ? Need help
Hmmm I'm wondering if it actually needs a driver directly for the PLM to use it this way tho with the PH/PLC combo. I mean a PLM has an address right ? Same as any other switchlinc, KPL or lamplinc. From what I understand you can use the PH/PLC to link a switchlinc to another device for example. Wouldn't the PLM just be another device ? I don't need PH to control any lighting. Just setting up and maintaining links when I need to update. But maybe I'm being too optimistic. It all just sounds too easy.
I was in your same shoes months ago when I went with the PLM and was using CQC. It was a pain to link all my devices and create groups on the PLM to use with CQC, and I was trying to get PowerHome to add support. CQC's ability to create PLM links has improved since then, but my CQC project is on hold anyway.
I think you could fool PowerHome by adding the PLM as an ApplianceLinc, and you MAY be able to create links - but I'm not sure if they'd work correctly.
If you give it a try, good luck and please post back your results!
Thanks Mike, I'll try to get in touch with Dave at PH to see what he thinks. Who knows, maybe PLM support is just around the corner.
Would make life a lot simpler.
