thewireguy
Your other and cheaper option is a analog camera with a Axis video encoder. You could get a 4 channel video encoder and 4 cheaper analog cameras for less then $1000 bucks.
I use Axis encoders pretty regularly in on a project that I am not necessarily open to discuss publicly. That said, I am not certain why one would suggest using one for home surveillance. If you have to run coaxial cable to the camera anyway, why not get a DVR card that supports analog cameras directly, rather than converting to IP video before it gets to the PC? There are products available such as the GeoVision or AverMedia cards that accept the analog feeds directly and can make the analog video just as easy to access remotely over Internet connection as using an Axis encoder. Also, while not certain about the AverMedia, they come with DVR software as well, along with some rudimentary forms of video analytics, allowing the DVR PC to record to HDD only with certain conditions occur. Such as, any motion in the picture, or simple tripwires, so recording is triggered by someone walking up your driveway, etc. This video is archived for either some set time, or until its overwritten by new data days or weeks later - depending on the amount of HDD space you have. The Axis card alone wont do any of this, and is only good for converting analog video to IP video. The only reason I would suggest an Axis card is if I were doing cameras on a detached building/garage and needed the data sent back (via IP) over a wireless access point or bridge connection.
Even then, I would personally have to rule out running cable from the remote location to the DVR PC in the home. The conditions where I see this is 1) the distance is too far for a coaxial run such as LARGE facilities or 2) cant or simply dont want to run the coaxial cable between the locations
Well the main reason I recommended the Axis server is, he was talking about IP cameras and price. If he goes with the encoder now he will have the NVR software so if or when he upgrades to IP cameras he will not lose any money. If he goes with the DVR card now you will have to buy the software when he upgrades. (I think GeoVision has hybrd software now) I would us a video encoder over a DVR card any day but that is my professional opinion. For a 4 camera setup you will not see the advantages of say 36 cameras. With the encoder you push the processing power off of the server and onto the encoder when it comes to motion detection. Also, there is a lot cool stuff you can do with the trigger in/outs on the encoders and they have better image quality then a DVR cards.
