beaumeri
Hi,
I have 2 heat source on my house and was wondering if we can hook 2 heat source to the same HAI thermostat (RC-2000 or RC1000)? The HAI thermostat are controlled by my CQC server.
My first source and main heating source is Radiant floor with 24 volts thermostat (Aube TH135) that trigger solenoid. Then the solenoid is open, it trigger the intant heater and water pump.
My secondary source is forced air with zone controller so only the calling zone get the heat or cold.
Can I connect each zone to both system in a way the first stage of heat would trigger Radiant Floor and the second stage would trigger the forced air heat?
BTW: My forced air is a Lenox System CBX27UH-036-6-02.
My zone controller is from Retrozone and is a RED-4 http://retrozone.com/Catalog/panels.htm
Any help is appreciated
