So I got my repeater installed on a subpanel in my detached garage. I tried adding it to UPStart per the HAI flyer that came with it, and UPStart, running from a PC on the same subpanel, couldn't find the repeater. I usually use Dealer Access to do all my UPB programming and have only attempted to do some debugging with UPStart, but when I tried to do a network discover on UPStart the program could "see" all my switches, but would do a bunch of retires and then fail to add any of them (I let it try the first 3 since it took a good 2-6 minutes to attempt each one).
Repeater LED is on (blue) and it flashes red and gives a slight buzz when a UPB command goes out on the powerline, so I assume it's functioning correctly.
I also had some trouble adding 2 new switches (new in box, relatively current stock since they now have Leviton branding) and both failed when enrolling in Dealer Access at various points of the enrollment process, although they enrolled "enough" to be controlled. I've never had a switch fail to enroll, and I also tried turning of the repeater at the two breakers to no avail.
I'm also having some trouble getting 100% on switch status (i.e. someone turns on at the wall and the OPII updates) and my switches are missing a command about 1 out of 20 times.
Any idea what could be going on here? When I first installed the system about 2 years ago I had near 100% reliability, and then it slowly tanked. I moved the PIM to another outlet and that got me to about 95%, but with the repeater install yesterday I'm a bit surprised to be seeing problems. Am I missing something with UPStart or should network discovery usually find everything and add it to the network without any major hassle?
