felixrosbergen
Assuming all wires (including Aux) are run to the location of the enhanced hub, are these statements true:
1) When connecting switches in a 3 way setup, only one hub termination point is used.
2) when connecting switches in a 5 way setup, two termination points are used.
3) One must determine where the load enters the circuit in order to identify the master switch.
4) 3 conductor wires from the AUX switch must be run back to the enhanced hub where the master communication wires will terminate, even if this is on a different floor.
5) Scene switches require only 2 wires, Tx+ and Tx-.
As an aside, where would a scene switch be used in place of a standard switch? Or would a scene switch be more appropriately installed in addition to other switches?
btw here's how I ran my CAT5e to the switch location. I can provide a closeup if anyone wants to see the clips I used.
thx
CB
For 1) and 2) , note that note all hub termination points are the same. Some (most) are intended for 3way and 1 per hub for 4/5 way.
3) Not sure if this is really the case, see my post above to beelzerob.
4) In some cases it might be easier to just run the 3 conductors for the aux from the aux to the master switch rather than running 3 conductors from the aux to the hub and there connecting them to the 3 conductors from the master switch. Your method would be a cleaner install, but potentially a lot more wire. Master switches have 5 LV wires (2 for communication and 3 for aux control).
5) and HV wires. I didn't realize this in the beginning. The scene switch use HV as well.
Regarding the picture it seems sensible. For a 5 gang however you have theoretical potential to be needing 1 x 2 conductors for communication and 5 x 3 conductors for AUX control. This makes a total of 17 which exceed the 16 conductors provided by the 2 cat5's. However from what i understand you can combined the COMMON wires for the different auxes so that woudl solve that issue. TONY PLEASE CONFIRM.
Are you sure you can get switch over plates for 5 gangs? Also i noticed the boxes are metal...it's ofcourse way to late in your case, but for other readers the use of metal boxes could prevent you from using insteon or other RF based lighting technology should you decide not to do ALC or something happens and ALC is no longer viable.
I have quite a few 4 gang boxes (plastic) in my house and we have trouble keeping them level. With the pressue of the wires the tender to 'droop' a bit and the builder had to go back and adjust them all after the sheetrock was up and i found them not acceptable. Maybe the metal actually prevent that...
Also the builder left the house with all toggle switches. I asked them to do all decora, but that was $600 extra so i passed. What happens now is that when you don't 'upgrade' all switches in the same box at the same time you will have a hard time finding cover planes with the right toggle/decora combination. The solution is one of 4: A) Start of with a full ALC install (pricey) :lol: Use all decora from the start (probably the smart thing to do 3) upgrade all switches int he same box at the same time (this is what i plan to do 4) get a few non automated decora switches (cheap) and swap the toggles you are not upgrading for decora when you upgrade 1 or more switches in the box (labour intensive).
