Could always host a chat session on the CT server, this way, everyone can learn from it once the the transcript has been posted. We used to invite manufacturers, etc. every Friday around 8-9pm EST, but it can be any day/time.
I like the idea, but admit that I am unfamiliar with it. Where can I learn more.. For example, can I send Live video?
TS
One thing that I am really struggling with is a dimmer vs a relay. These days when a fixture may be a dimmed load or a fluorescent it is just so nice to have the ability as in UPB to simply put 1 switch in and configure it for either load type. There has been at least 1 occasion when I have changed the type of load but yet did not have to change the switch. If the ALC switches could be configured that way, the same as UPB or JetStream, or probably others, it would make it a so much better choice.
Considering the dimmers and relays are about the same price they only need for a relay is fluorecent lighting and things like fans.
I actually don't know why TS used relay's in his staircase example.
I can easilly host a GotoMeeting using my company's account. This allows all to see you computer screen and has voice conference included.
Weekdays are no good for me...unless it's next monday which is a holiday for me.
I've had concerns about OnQ's products because the scene switches don't seem to appear as polished as some other solutions. Anyone heard yet about possible plans to have backlit scene switches?
Don't forget that you can use most anybodies scene switch. Well at least if you are using a controller like the Elk m1. More specifically you can use the best looking scene switches (like Litetouch) as long as they use a contact closure type. So the choice of scene switches is not limited to ALC.
God Bless
TS
God Bless
TS
Hey tony can you explain how one would go about this? The WAF seems to be a deal breaker on the OnQ Scene switches. If I were to be able to integrate a different scene switch I think I'd be over the hurdle. From the WAF point of view the OnQ Scene switches look cheap and antiquated. I'm using an Omni Pro II, how would I go about using a litetouch scene switch. Or can you provide a few manufacturers whose scene switch will work with the ALC system?
regards,
CB
God Bless
TS
regards,
CB
God Bless
TS
regards,
CB
Broconne's comment (next one in this thread) was exactly correct. Here is how a contact closure scene switch from any manufacturer works with any automation panel that is also setup to do security (like the M1 or Omni)
Security zones are set up to require a zone violation of a fairly long duration. This is so that brief power blips don't set the alarm off when armed (and is not a setting you can change). This is called loop response time. When you use a contact closure as a scene switch input, the user pressing the button must press it for at about a half second before the panel registers the zone violation. While this does not sound like much, it is a longer time period than the "bump" press that many users want to use.
So, they or you may press the button briefly and the zone may not register the press.
Outside of that, the Litetouch scene switch is a special order item which is not on our site.
TS
