I'm guessing he wants some sort of "house power indicator" and doesn't want the relay controlled.az1324 said:I'm looking for a contact closure relay built into a standard 120V plug. Does that exist? I'd like to plug it into a switched 120V outlet to provide a simple contact closure result.
Problem is the terminals for the AC coil are usually right next to the terminals for the contacts. If you want to switch low voltage from a 120 VAC trigger you will have high and low voltage wires living in the same enclosure. The wall wart solution will not expose you to any potential code violations. (And will ensure your low voltage circuit never comes in contact with 120 VAC)BLH said:BSR; That looks like a good solution. I also have never seen a 120 Volt relay with a set of prongs like a plug.
Another could be a 120 VAC relay in a enclosure with a short extension cord on the AC side.
And a less direct, but simpler (from a hardware perspective) solution for those who have an Elk panel, is to simply do a rule to turn an output on/off based on AC trouble. I already have some plans for this.BraveSirRobbin said:I'm guessing he wants some sort of "house power indicator" and doesn't want the relay controlled.
Unless you have your Elk on UPS power and want an immediate indication (so you can take any necessary action such as RD into your system before UPS power runs out).dscline said:And a less direct, but simpler (from a hardware perspective) solution for those who have an Elk panel, is to simply do a rule to turn an output on/off based on AC trouble. I already have some plans for this.BraveSirRobbin said:I'm guessing he wants some sort of "house power indicator" and doesn't want the relay controlled.![]()
That looks like what he's looking for, but wow... $60 for a relay with a 120v coil? Being the cheap kind of guy I am, if I had a need for this, I'd buy a relay (should be <$10 if you search), spend another couple bucks on a cheap extension cord to get a plug and outlet, and another few bucks for a box to put it all in.Rupp said:Is this what your looking for?
http://www.smarthome.com/prodindex.asp?catid=156
That's good that your able to do this but many aren't ....dscline said:That looks like what he's looking for, but wow... $60 for a relay with a 120v coil? Being the cheap kind of guy I am, if I had a need for this, I'd buy a relay (should be <$10 if you search), spend another couple bucks on a cheap extension cord to get a plug and outlet, and another few bucks for a box to put it all in.Rupp said:Is this what your looking for?
http://www.smarthome.com/prodindex.asp?catid=156![]()
