I am a residential HAI/UPB user but I chose to install a 2Gig panel in my wife's business for its simplicity and because we have Zwave locks in every office for security reasons (meaning Zwave was the chosen technology). The automation requirements are minimal from what I am used to at home so the 2Gig was a good fit. Everything works like a charm but I am reluctant to install Zwave switches on two locations.
1. Switch A feed 6 fluorescent fixtures with 3 T8 bulbs each rated for 32W. The ballast factor is 0.88 and the input wattage is 85 (not sure how the ballast affects the wattage computation). All the bulbs together come out to be 576 watts but I am not sure how the ballast affects the total. Switch is installed by itself (1 gang).
2.. Switch B carries the same exact load but it is installed in a two gang box.
I realize that I would need to install a on/off switch and no a dimmer. However I see that most switches are rated for 600W incandescent. Does anybody know if a 600w switch would work? I would have no problem spending the extra cash for something with a higher rating but I really cant find anything greater. I did notice that the GE switches say 960W on the box but the manual states 600W incandescent.
Thanks guys.
Thanks guys.
