Help with ekeypad after changing routers
dbegun
I recently moved from a Cisco router to an AirPort Extreme. I had my ekeypad app on my iOS devices set up to control my ElkM1 and was able to arm and disarm the system from my device. I had it configured with port forwarding for the IP address assigned to the elk.
Now that I have moved to the AE, I am unable toss the ekeypad. I have the. We IP address of the Elk but I am unable to get the port information. I have tried using the port I had previously and inputted it into the configuration setup screen but I keep getting an error that i can't access the elk.
I was able to get my mobilinc software set up to access the isy99 but so far no luck with the elk. Thx.
Use ELK RP2 to check the TCP/IP settings tab on the ELK M1XEP setup screen.  The secure port is shown there.  If you didn't change it, it should be 2601.
Thx again. It is 2601 but I still cannot connect to it. It must be the way I am port forwarding on the AirPort Extreme.
